Brief Description: Made Dividers for Cowl Inlet Rings and Epoxy
I rethought the application of the epoxy slurry around the cowl inlet rings. I decided to make dividers for each side of each ring for the epoxy. This should allow the separation of the cowl to be done more easily. Scrap aluminum was used and then the rings were trimmed out of the scrap. The dividers nest into the rings.
