Brief Description: Cowling Halves Glassed Together
The cowling has some large gaps at the front corners and at the aft corners. Jeff Paden suggested putting the two halves together and then glassing the inside together. After the gaps are filled, a new straight line can be cut into the cowling.
I epoxied one layer of glass at each corner on the inside. Flox was added to the epoxy and then applied to the gaps.
