Brief Description: Installed Camlocs on Bottom of Lower Cowling
I double-checked the spacing of the camlocs riveted to the bottom brackets. The left side is at three-inch spacing for the three holes. I used the Unibit to enlarge the holes in the lower cowl on the left side up to 15/32" size, per the plans. I then installed the fastener grommets in these holes. i installed the lower cowling to the fuselage to ensure that the studs lined up with the receptacles. The cowl was removed and I started to work on the right side. The center hole had to be moved 3/16" inboard because of the gascolator drain hole.The holes were enlarged and the fastener grommets were installed. The cowling was placed back in place and the studs were all screwed into place.
The left side of the lower cowl ready for the receptacle holes
The lower cowling before any camlocs are installed
