Brief Description: Drilled Cowling Sides to Support Braces
I drilled the sides of the bottom cowl to the support braces with four inch spacing. Both of the cowling side supports force the top cowling away from the bottom. This is because the supports need to be curved to the contour of the cowling. I bent the front top edge of the right support in the vise. I had to bend approximately the first 12'' of the top part of the support.
Left side drilled to support braces
The right side drilled to the support braces
The right side support brace curved to cowling contour
