Brief Description: Worked on Side Supports because of Misfit of Top
With both cowlings in place, I clecoed the side supports to the bottom cowling again to check the fit. With the side supports in place, I found that they push the top cowl out of position because of the curvature of the cowling going forward toward the inlets. I took the side supports out a few times pondering different options, such as cutting the forward 6-8" off and rounding the top portion.
The cowlings in place with the top being pushed out
The left front inlet and the large gap
Looking at the inside of the cowling and the side support
