Brief Description: Drilled Right Axle/Installed Bonaco Brake Hoses
I drilled the holes in the right axle for the cotter pin like I had done for the left axle. I inserted cotter pins in each axle to ensure that they could be inserted and that the holes were the proper size. I had ordered flexible stainless steel brake hoses from Brett-Bonaco on 10/4/10. I received the brake hoses and screwed them to the fittings on the firewall and the brakes.
