I found that I did not tighten one bolt on the right gear, so I had to pull off the tire again using the jack. I then tightened all of the bolts and applied torque seal on all of the bolts. I received the SIRS Navigator compass and bracket from Doug Weiler. I purchased it from Doug who advertised it on VansAirForce.Net. Serial no. 712497-07.
