Brief Description: Riveted Remaining Side Panels/Screws
There were a few rivets on the side panels that had to be riveted. That was done. The most-forward screw on each side of the side panels had to be shortened and a short nut used, to prevent interference with the screw and nut through the vertical front tube of the frame.
Walt Halloran helped me put the canopy back on the fuselage.
