Brief Description: Added Bondo to Fuselage/Sanded Fairing
I checked the area on both sides of the fuselage where the new fairing will join with the roll bar fairing. The areas did not have any bondo to make a smooth transition, so more bondo was mixed up and spread in the areas. They were then sanded.
The roll bar fairing had the two ends, outer and underside, sanded with #60 grit sandpaper, in order to make a smoother transition with the new fiberglass fairing to be made.
