Brief Description: Primed Aft Fairing after Sanding
I used the orbital sander with 80 grit paper to sand the SuperFil off the exterior of the fairing. I then used 120 grit paper to hand sand the inside and exterior. I wiped down the fairing with acetone to clean off the dust. I primed the entire fairing to see how the SuperFil and the fairing looked re pinholes and low or high spots.
