Brief Description: Sanded and Drilled Fairing to Canopy
I used the Mouse sander to sand the underside. After about two hours of sanding, the majority of the sanding is complete. The duct tape and the cardboard template were taken off the canopy and fuselage. I placed the fairing on the canopy. The fairing was taped into place on the fuselage to hold it in place. Using the #30 hole-finder, I drilled the first hole in the center and then worked out left and right from there to match-drill all of the holes in the canopy. I marked the front edge of the fairing at 5/8" forward of the rivet holes. The fairing will be trimmed along this line.
