I looked over the painted parts that Walt did. I found that the top and side of a tip-up mod piece was not completely painted. I need to give that back to Walt. I assembled the canopy rollers. I bolted the handles into the roll bar and used AN3-5A bolts, with AN960-10 washers, to bolt the handles in place. The center track for the Koger sun shade was screwed into place on the canopy frame. The velcro buttons were Superglued into place and then screwed in. I assembled the tip-up mod pieces that are bolted to the canopy frame and bolted them in place. The spring attaching them was shortened, but not short enough. The interior canopy side skirt was clecoed to the canopy frame and then pop-riveted in place.
