Brief Description: Practiced Drilling with Plexiglass Bits
Doug Robison drilled some holes in a scrap piece of plexiglass using a plexiglass drill. We found that the best technique will be to use a cordless drill at a slow speed. He tried to countersink the hole using the zero-flute countersink bit and then used a normal countersink bit. Both bits worked pretty well.
