I applied the FireSafe caulk to the corners of the firewall recess, as well as to the extra hole drilled in the firewall under the right instrument panel rib.
I used a #43 drill bit to drill a hole through the plastic grip and top of the right control stick grip, and then through the stick itself. I tapped the hole in the stick for a 4-40 screw and installed the grip handle and the grip top with a 4-40 1/4" long screw.
I worked with Dave on bending the canopy bows.
The right stick grip screwed to the stick after drilling and tapping
