Brief Description: Masked and Primed Wing Components
Walt Halloran masked off the access panels and wing tips in preparation for painting. A final wipe-down of all surfaces was done just prior to priming. Walt used DX330 wax and grease remover for the final wipe-down. Walt then sprayed two coats of epoxy primer on the wings, ailerons, flaps, elevator trim tab, and access panel covers.
