Brief Description: ??Talked with Jason-Aerotronics re Fuel Guardian
I talked with Jason Smith-Aerotronics re the Fuel Guardian wires made by them and the lack of documentation from them. He suggested pulling the Dynon D-100 out to get to the processor. This allowed access to the FG processor and put a multimeter to the wires into it. I was able to determine the wiring in the Molex connectors made by Aerotronics. The correct wiring for the Molex plug from the fuel tank is pin 1- , pin 2- , pin 3- , and pin 4- . The ?? wire from the fuel tank is to be snipped off because it is an extra.
Jason will mailing three male Molex kits to use. The FG wires from the tanks will be cut and have the pins and connectors applied to them. This will correct the opposite tank indication.
