Brief Description: Positioned Smoke System Remote Switch on Panel
I had laid painter's tape on the panel and then measured and laid out the position of the holes for the remote switch. I drilled the pilot holes and then enlarged the holes with a Unibit to the appropriate sizes. I deburred the holes with the Unibit and temporarily inserted the two switches and the warning light.
Tape in place on the panel prior to marking the center of the holes
Holes drilled for the two switches and the light
The switches, light and cover plate temporarily in place
