Brief Description: Add Static Line Bushings/Riveted Cable Bracket
I pulled the static tube out from the T connection and out of the holes along the left side of the fuselage. The holes were enlarged to 7/16" for plastic bushings to be inserted. I inserted the bushings and re-ran the tubing. I then riveted the control cable bracket to the instrument subpanel. I drilled another hole in the subpanel flange for another Adel clamp. The light dimmer wire was then clamped in place.I also clamped another wire to that same flange. I started to swap out the two AN515 screws for the ground block with two cap screws.
Static line with bushings installed in the bulkheads
