Baker's RV-6
Date:  12-18-2009
Brief Description:  Lt. Dimmer Connectors/Air Vents/MB Antenna
I received the Dynon pitot tube, Nylabraid, shielded wire, screws, and connectors from Aerotronics. I installed the connectors to the light dimmer and its connector. I clamped the control cable bracket to the instrument subpanel. The air vents were installed and the black tubing was connected to the NACA vents. I screwed the marker beacon antenna in place using AN3 bolts, instead of the screws provided. I need assistance with putting the screws in.
The extending screws attached to the light dimmer
The light dimmer and connecter fixed in place
The right air vent in place
