Baker's RV-6
Date:  11-4-2009
Number of Hours:  3.00
Brief Description:  Work on Fuel Guardian/Nutplates
I found that three wires had come out of the Fuel Guardian, a white and two blue and white wires soldered together. The white wire went to position 5 and the two blue/white wires went into position 2. I positioned the Fuel Guardian onto the firewall side of the instrument subpanel and attached it to the subpanel with two #8 screws going into K1000-08 nutplates. I attached two MS21919-WDG4 Adel clamps to the Fuel Guardian wire bundle and riveted nutplates to the subpanel. One nutplate was riveted to the underside of the flange and the other to the cockpit side of the subpanel, in order to relieve pressure on the wires. I positioned and drilled holes in the subpanel for the Unswitched Audio base. I riveted nutplates in the subpanel on the firewall side. I drilled one of the brackets to the left rib at the panel end and drilled it for a floating nutplate.
The Fuel Guardian positioned on the forward side of the instrument subpanel
Adel clamp for the Fuel Guardian wire
Unswitched Audio base attached to the instrument subpanel
