Brief Description: Drilled Instrument Panel Brackets for Nutplates
Measured and drilled holes in the two center panel brackets for the screws. The left bracket has holes 1 15/16'' separation and the right bracket has 1 3/4'' separation. Used the nutplate jig to drill the holes in both brackets. Worked with Jeff Paden on how to rivet with the hand squeezer and the pneumatic squeezer and riveted nutplates to the left bracket.
Instrument panel brackets with nutplates installed
