Talked with Jason-Aerotronics re wig-wag light set-up. He needs to see my wig-wag component, but he will probably have to add a switch for the pulse light. The taxi and landing lights will each have their own switch. The avionics switch will be moved to the right side of the master switch. The ELT switch will be swapped with the CO Guardian, so that the light on the ELT can be seen, if activated.
