Brief Description: Carb Heat Cable Clamped to Bracket
Jeff Paden slightly bent a 1/16" bracket and installed it on the right bolt connecting the air filter and the attach bracket. An Adel clamp was applied to the front portion of the carb heat control cable. The clamp was bolted to the new bracket to stabilize the cable.
