I applied spark plug lubricant to each of the spark plugs. The plugs need to be torqued.
The oil cooler was screwed to the baffle and the oil lines were connected to the cooler, but not tightened. The oil cooler will be removed. The flange on the right side by the upper engine mount needs to be cut off, so that there is no touching between the cooler and the mount.
