Brief Description: Oil Line Routing/Fuel Line Firewall to Gascolator
I rotated the left Adel clamp on the oil pressure line from the transducer, in order to get a straighter run. I looked at the distance/run from the firewall fuel fitting to the gascolator. I believe that the Bonaco product, AN818-90-6D, will work for me if Brett can make it 2 1/2'' long. I inserted the battery into the battery case on the firewall. I installed the exhaust hangers onto the engine case bolts and the exhaust, per Vetterman's instructions. The rubber tubing was also installed. I believe that the exhaust system is now complete!
The Adel clamp closest to the oil pressure transducer was rotated
