I am not going to use a primer system, so the primer lines were removed and marked for future reference. I also removed two Adel clamps that were placed in the intake pipes for forward cylinders 1 & 2 that held the primer lines in place. I tightened up all bolts on the engine that were removed with the primer lines.
The primer line system
Cylinders 2 and 4 with the primer holes still open
