Baker's RV-6
Date:  10-23-2010
Number of Hours:  1.00
Brief Description:  Began Cabin Heat Muff Installation
I received the latest Aircraft Spruce order and put some of the hardware away. I had ordered three brass plugs, AN913-3, to close up the primer holes in the cylinders. This was the wrong size for the hole, which is 3/8''. The diameter of the plug is about 0.662''. I'll have to get replacements. I also ordered some stop nuts, MS21042-3, for the exhaust hangers. I should have ordered the gray lubed stop nuts, instead of the ones ordered.
I started to install the cabin heat muff. I spread the muff apart and pulled it onto the right exhaust. I unscrewed one clamp and rescrewed it onto the right exhaust. I bolted the last two hangers in place to join the two exhaust pipes together, with the rubber tubing and clamps.
Cabin heat muff
Cabin heat muff
The center exhaust hangers in place
