Baker's RV-6
Date:  10-16-2010
Number of Hours:  3.00
Brief Description:  Installing the Exhaust Hangers
I installed the left and right exhaust hangers on the engine mount per Sam Buchanan's photos. I placed the angle attachments onto the collar over the exhaust and then attached the supports to these attachments. I wrapped some Rescue Tape around the engine mounts and then installed Adel camps with supports on the mounts. I cut the rubber tube in four-inch lengths and then clamped two lengths over the supports. Installing the supports in this manner, rather than using the bolts on the oil sump, results in not having enough hardware. I placed another order with Aircraft Spruce for hardware.
The left exhaust hanger
The left exhaust hanger with the Rescue Tape
The two exhausts with the hangers in place
