Baker's RV-6
Date:  10-5-2009
Number of Hours:  3.50
Brief Description:  P/u Preservative Oil/Sprayed Engine Interior
I drove to Wakeman Airport and picked up about a quart of preservative oil from Tom Cullen. I pulled all eight dehydrator plugs from the engine and sprayed the interior with the oil. I took the dehydrator plugs home, opened them up and dried the material out in the oven at 170 degrees for about fifteen minutes. I reinstalled the plugs in the engine after the oil stopped leaking out of the bottom plugs.
I began putting the interior into the fuselage for the shop tour the next evening.
Engine cylinders sprayed with preservative oil
Putting the cockpit together for shop tour
Putting the floor in for the tour
