Brief Description: Sent Check for the Prop/Polished Bolts for Wing In
I sent a check for $1,900 to Radomir Zavic for the prop/spinner. He will probably deliver the prop to me at Medina Airport by flying with a friend in his RV-10. He estimates coming up on 5/16, but will let me know.
I purchased some 3/8" bolts at Home Depot. I am grounding off the threads and polishing the shanks. These bolts will be used as bolt replacement when the wings are installed.
I also used the die-grinder to bevel the vertical edges of the aft ends of the longerons. The longerons are rubbing against the rudder skin at the 35 degree position. I need to grind off some more material.
