Baker's RV-6
Date:  9-22-2012
Number of Hours:  0.30
Brief Description:  Rerouting of the Oil Line for Hobbs Meter Switch
With Walt's help, we figured out how to get an oil line to the Hobbs meter switch on the manifold. A #4 tee fitting, AN824-4, is required. The oil line to the oil pressure transducer will be split in two. The tee fitting will be inserted in the middle and another steel-braided line will be attached to the fitting and run to the manifold next to the Hobbs meter switch. The opposite hole on the manifold will be plugged.
The tee fitting and the plug
