Brief Description: Installed Carb Air Inlet and Safetied
I received another Aircraft Spruce order, which included four MS20074-04-03 bolts. These bolts were used to install the carb air inlet. The bolts and air inlet were tightened and then safetied on the left and right sides. A section of 3" Scat tubing was cut and clamped onto the carb air inlet.
The carb air inlet on the carb with the Scat tubing
