Baker's RV-6
Date:  1-17-2012
Number of Hours:  0.50
Brief Description:  Found Problem with Orientation of Carb Heat Inlet
The air filter assembly was held up to the carb inlet. I discovered that the carb heat inlet was angled forward and it should have been angled aft. The carb heat inlet will have to be reversed.
The carb heat inlet pointing forward, away from the carb heat muff
