Brief Description: Sanded Flox/Applied RTV under Carb Heat Deck
Jeff's grinder was used to sand the flox on the carb heat box. 60 grit sandpaper was then used to finish the sanding. The gaps were filled in with the flox. RTV was applied on the underside of the carb heat deck to prevent fretting of the deck with movement of the ram air door.
