Brief Description: Flox in Gaps/Cut Out Alum Ring for Air Filter
Flox was added to the carb heat box in the forward and aft areas.
A large ring was cut out of an aluminum piece for reinforcement of the air filter area. The inside cutout was done by drilling the perimeter with a #30 bit and then smoothing the edge with a file and then the die grinder and Scotchbrite pad.
Flox added
Flox added to the gap at the forward area of the carb heat box
