Brief Description: Reinstalled Scat Tubing after Bending Wire End
I used the info from one of the EAA Homebuilders videos re installing Scat tubing and putting the wire end out of the way. A bend in the wire tip was made in each end of the Scat tubing, except for the end going into the heat box. The wire was then pushed up into the tubing so that the end would not catch on the tubing.
