Baker's RV-6
Date:  10-18-2011
Number of Hours:  2.50
Brief Description:  Installed Scat Tubing for Heat Muffs
The Scat tubing from the engine baffle to the heat muff was clamped into place. Per Tom Cullen's suggestion, I tied off the Scat tubing to the engine mount with Koroseal lacing. The other Scat tubing from the heat muff to the heat box was also tied to the engine mount with the Koroseal lacing. Rescue tape was wrapped around the engine mount areas where the lacing was going to be wrapped around the mount.
The Scat tubing
The Scat tubing
Scat tubing tied to the engine mount with Koroseal lacing
Rescue tape wrapped around the engine mount
