Baker's RV-6
Date:  9-21-2011
Number of Hours:  3.00
Brief Description:  Drilled Firewall for Passthru for Ignition Wires
The P-1 connector will have about twenty wires going into it. The first five were separated and run thru the connector.
The left side of the firewall was drilled for another passthrough. This one is for the Lightspeed ignition wires. The passthrough was installed and the wires were run thru.
The first five wires to go into the P-1 connector
The second hole drilled in the firewall for a passthrough
The firewall passthrough in place for the Lightspeed ignition wires
