Baker's RV-6
Date:  9-13-2011
Brief Description:  Finished Crimping #8 Wire Betw/Shunt and Relay
A second terminal was crimped onto the end of the #8 wire that will be installed between the ammeter shunt and the master/starter relays. The Swedge-On tool was used to crimp the terminal. Heat-shrink was applied to the terminal and a terminal nipple also laid on the wire.
The wire was screwed onto the terminal end of the starter relay and on the lower terminal end of the ammeter shunt. The wire was clamped to the engine mount by adding the clamp to the clamp holding the right brake line.
The wire ready for installation
The starter relay with the wire screwed in place
The wire clamped to the engine mount
