Baker's RV-6
Date:  9-1-2011
Number of Hours:  0.10
Brief Description:  Dehydrator Plug/Ammeter Shunt Fuse Links
I dried out some dessicant material using the light method. The dehydrator plug on the #4 plug was changed out.
I had asked Jason-Aerotronics for some 26 ga wire and he was nice enough to crimp terminals on one end of each length of wire. These two wires will be incorporated on the ammeter shunt to be fusible links for the amps high and the amps low wires for the Dynon. The two wires and terminals were screwed in place on the shunt.
The dried out dehydrator plug
The ammeter shunt with the fusible links
