Baker's RV-6
Date:  8-11-2011
Number of Hours:  0.50
Brief Description:  Oil Cooler Door Shutter Cable/Oil Fitting
Holes for the nutplate on the aft baffle were drilled for the cable.
The oil fitting on the engine was rotated so that it was a little farther away from the engine mount. A new oil fitting will be installed in the other hole.
The nutplate holes drilled in the baffle
The oil fitting rotated away from the engine mount
