Baker's RV-6
Date:  8-11-2011
Brief Description:  Labeled Wires/Added Sealant around Tanis Oil Sump
Wires for the oil pressure, fuel pressure and oil temperature were labeled at the ends just before the wire go thru the firewall. Heatshrink was used to cover the labeling. The wires were then run thru expandable sleeve wrap and the wires were run thru the grommet above the rudder pedals.
Sealant was applied around the edges of the Tanis oil sump heater.
The wire labeling
The wire labeling
The wires run thru the grommet in the rudder bracket
The oil sump heater with sealant added around the edges
