Baker's RV-6
Date:  6-20-2011
Number of Hours:  1.00
Brief Description:  Oil Cooler Shutter Cable Installation
The doubler for the bulkhead was riveted in place with AN470 flush rivets. The cable was installed and then the routing of the cable had to be worked out. The run of the cable would take it next to the rudder pedals, which would not be good. Instead I made a loop out of the cable, drilled a hole in the lower longeron, and installed an Adel clamp with the cable. The loop might have to be rerun because it will probably vibrate against the fuselage side.
The doubler riveted to the bulkhead
The cable installed on the bulkhead
The cable looped
The cable looped
