Brief Description: Split Firewall Pass-Through for Ignition Wires
The LSE ignition wires had a terminal end already placed on the cockpit end of them. The terminal is large and does not fit thru the firewall pass-through. Jeff suggested that the pass-through be slotted about 1/8" so that the wires can be slid thru the pass-through and then the firewall sealant can be wrapped around the cut opening. He cut a slit in the pass-through and the wires slid right in. The pass-through was screwed in place on the firewall.
