Brief Description: Notched Aft Left Baffle and Plenum
The baffling was reinstalled on the engine and the plenum was put in place. The baffle with the oil cooler had to be notched out for the plenum. The plenum corner did not fit properly into the corner of the two baffling pieces, so the side of the plenum was removed This will be glassed in later.
