Brief Description: Ran LSE Output Wires/Oil Temp Sensor
The RG-400 output wires for the LightSpeed ignition were strung out and attached to the Plasma CD module. The wire needs to be run thru the firewall.
The oil temperature sensor was screwed into the hole just forward of the oil filter. Anti-seize was applied to the threads. The sensor bottomed out because a crush washer needs to be installed. The crush washer was not included with the Dynon kit, so a few were ordered from Aircraft Spruce.
The Plasma CD module with the output wires
The oil temp sensor screwed in place without a crush washer installed
