Brief Description: Installed Steel Fittings in Oil Cooler
I screwed in the steel fittings, instead of the aluminum fittings, into the oil cooler. Anti-seize was applied to the threads. Pacific Oil Coolers (oilcoolers.com) has a good web site indicating that the fittings should be steel instead of aluminum. AN970-3 washers were marked for trimming. These washers will be inserted next to the oil cooler flanges with the aluminum tubes between the flanges and washers.
The large washers marked for trimming with the screw tubes
