I had ordered and received a replacement fuel pump overflow plug and installed it today. The brass tube off the original plug broke off at the weld when I had attempted to push the plastic tube farther up the tube. Anti-seize was placed on the threads of the plug. The plastic tube was pushed onto the brass tube and safety wire was wrapped around the tubes.
The EGT and CHT wires were run thru the fire sealant wrap and the clamps. The sealant wrap was tightened over the collar of the pass-through with one clamp. The second clamp will be used after the additional fire sealant wrapping is applied.
The fuel pump overflow plug with the plastic tube safetied
