Brief Description: Made Angle Support Brackets on Cylinder #3
I drilled the angle bracket on the left inlet ramp to the side engine support bracket.
I made an angle bracket for the side baffle on cylinder #3. Some builders using the James plenum have not installed a bracket, but I thought that the baffle was still high enough to warrant some additional support, so I made the bracket. I used a bracket of .063" thickness, rather than the .032" the plans called for. After drilling the bracket in place, I checked to see if the flanges could be riveted together with the squeezer. The bracket was interfering with the squeezer, so I trimmed some of the corner off. The bracket was riveted to the baffle.
The left cowl inlet ramp
The side baffle and support bracket for cylinder #3
