Brief Description: Drilled Ice Drain Hole in Oil Breather Tube
I drilled a hole of 7/32" diameter about 7" from the lower end of the oil breather tube and then made it into an oval. I cleaned up the edges and used an 1/8" punch to indent the lower end of the hole. The tube was then reinstalled in place on the firewall and clamped to the engine.
